2 hours ago
Few calls are directly going to Voice mail. This includes my doctor's office calls and other my friend's call. Not sure why only a few calls are blocked on my phone. How to resolve this issue. I am frustrated with this issue.
Any help is appreciable.
Advance in thanks.
an hour ago
@cybersadiq Sounds like the port didn’t complete and you only able to recive calls from other PM /koodo/telus customers and not from the other carriers why only some come thru . Do you remember replying YES to the confirmation text to port ?
you may need support to help you sort it out and talk to Koodo to see if they will verbally approve the number transfer if you no longer have the Koodo SIM card
an hour ago
HI @cybersadiq
how long you ported your number ?
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (envelope on top right), check for the number and call
an hour ago
I did transfer the number from the old provider to new one. My old provider is Kodoo. But why only few calls are going directly to voice mail, but not for all. And I don't have an old sim with me to test or check.
an hour ago
This happens to me for he calss i blocked.
I block some numbers and automatically the calls goes to vm. My phone doesn't ring. In these situations, it only shows there is a voicemail.
2 hours ago
HI @cybersadiq
did you just join PM? or the issue just started lately?
but you sure you can receive some calls? just not all?
you sure you didn't enable "Silent unknown caller" feature? that is a feature on the device that will block any calls not current on your contacts on your phone
and what phone do you have?
2 hours ago
@cybersadiq You didn’t just port a number over to public mobile did you ? If you did did you leave old providers sim in the phone to reply YES to confirmation text to port ? And can you test the old providers sim in the phone to see if it still works , if it does then the port wasn’t complete . I can send you the porting team number private message to fix if this is the case .if that’s not the case I’m not sure what would cause that to happen
