11-27-2025 12:24 PM
I am no longer able to receive incoming calls. Thankfully voice-mail is still working so I can call them back... .
They don't register as incoming,, missed or declined. There is no log of the call; I will just see vm notification pop up.
I am restarting the phone after I post this.
Is there anything else I can do? Or is it all 5G now like they warned us in March?
It's a samsung galaxy s10. I think SIM is 5-7 years old
Thanks!
11-28-2025 09:11 PM
Update got new (to me) 5G phone
Used old sim and can receive calls again
Thanks !
11-27-2025 06:01 PM
OP says she can make calls...just can't reliably recieve calls. If it was a VoLTE issue, I don't believe she could call out either. I think she should try her sim in a different cellphone to see if things improve.
don't buy a new Public Mobile sim card...they don't usually die (unless abused). The sim card you have will work on any currently offered plan within Public Mobile. Try it in a different cell, is my suggestion.
11-27-2025 03:55 PM
can you make calls?
you have a Galaxy S10, it is not on PM's VoLTE list, and that is likely the cause
PM uses Telus and Bell Network. Telus is in the process or realigning some 850 Mhz channel on its 3G network for other use. People who have phones that is not whitelist on PM VoLTE list (some older phones) and those do not have 1900Mhz (phones that are not designed primarily for North America) will have voice trouble.
So, depends on the phone you have, it might not be something that can be fixed unless you change phone, or if your phone has VoLTE, then you can move to Koodo or Telus
but confirm if your phone's VoLTE is compatible with PM's network here:
https://www.publicmobile.ca/en/get-help/articles/volte
11-27-2025 03:44 PM
I could ask afriend but what am i looking for? Just see if I can receive.calls?
I dont get all this stuff
If its.a.sim thing do I order from pm or buy anywhere? How do I keep.my number
Do I need a new sim? My phone is definitely not 5G compatible and PM warned in March that it may stop working after March 17th or so
11-27-2025 12:55 PM
My 5 or so year old sIM will work on 5G?
I'm like the other poster: I don't understand 5G VOLTE or sims
11-27-2025 12:50 PM
@Karyathena1 wrote:Yes I guess I'll need to order a new phone. It's annoying because I only buy new phones when the old one is slow and glitchy. This one works fine. Except I can't receive calls lol kind of key.
It's weird that I can make calls
If you can make calls successfully, then it's not a VoLTE issue after all. You wouldn't be able to call on your cell ifr it was that.
Can you try the sim in a different cell ?
11-27-2025 12:35 PM
11-27-2025 12:26 PM - edited 11-27-2025 12:27 PM
could you try your sim in a different (newer) cellphone. Sounds like a VoLTE issue.
added ....https://www.publicmobile.ca/en/get-help/articles/volte
