CS Agent
JT1948
Trying to transfer from Telus and getting an error message Invalid Phone Number but it is a valid number, very frustrating.
2 REPLIES 2
Socrates8567
Hello
If you can, just sign up. Get a temp number and make sure it all works as it should. Once it's up and running, then log into your account and you can port over your Telus number with ease. You'll just have to put back your Telus sim card minutes before you port over so you can say yes to the porting request. Then once your sim card goes sos with telus, turn off the phone, put your pm sim card in and reboot. you should be back up and running with your telus number on pm.
@JT1948
send  a  private message   To CS_Agent
