09-26-2022 02:02 PM
Ordered andreceived a certified pre-owned phone. Order #305977 but did not receive the free SIM card that was advertised
JB
Phones
09-26-2022 02:17 PM
If you're close to a Telus or Kodoo kiosk in the mall...see if they have any PM sims available. Then ask CSA to credit your account.
09-26-2022 02:08 PM
@Johnpublic76 Yes, the missed the sim card sometimes, very often 🙂
PLease open a ticket with PM Support and they will send it back for you. But if you need one urgently , it is better to check with local Telus or Koodo store. It might take PM up to 3 weeks to send the SIM card alone
You can message PM support directly here:
![](/skins/images/34AB3B0FE78BBE11DBF186F131BC3766/responsive_peak/images/icon_anonymous_message.png)
