01-07-2024 06:00 PM - last edited on 02-20-2024 03:48 PM by computergeek541
Hey all,
I've been using an esim for the last six months or so and am going to be upgrading my phone soon. Looks like I can buy a new esim or physical sim for the new phone and the transfer process is similar. Any recommendations? Anyone made this transition on an android device yet?
Thanks!
02-20-2024 02:28 PM
@TrevorF1980 I never recommend eSIM it seems to be the general consensus here too just stick to physical sim until your forced to use the money grabbing esim
02-20-2024 02:26 PM
Your suggestion worked really well. It was quick and easy. I purchased the sim from Amazon. I totally get that esim may be the way of the future, but I wouldn't recommend it to someone who was setting up their own phone. Thank you!
01-07-2024 06:17 PM
@TrevorF1980 Will be up and running right away no lag time just sim swap the number put new sim in the phone and reboot the device
01-07-2024 06:17 PM
HI @TrevorF1980
yes
all you need to do is to buy a new PM physical sim from Telus or Koodo store
login My Account, Profile page, click on the pencil besides sim card and update the sim card number
Then put the new phsyical sim in a phone, reboot and done!!
01-07-2024 06:15 PM
This is great. Will manually changing the number automatically delete the esim profile on my old device? What's the lag time like before the new sim is up and running?
01-07-2024 06:08 PM
01-07-2024 06:06 PM
You guys are really on it! Thanks!
01-07-2024 06:02 PM
@TrevorF1980 If you like to upgrade phone often as I do best to stick with physical sim you have to rebuy esim every time . And you can do this in your account once you have SIM card in hand profile page and someway the number
SIM SWAPPING profile tabs
Note only do this on lap top or computer/ not mobile device
01-07-2024 06:02 PM
HI @TrevorF1980
i suggest you buy a physical sim.
esim is good, but it will cost you $5 to each time you change phone. Some people reset phone by mistake or need to reset phone for repairs, and they need to pay $5 agian for esim
01-07-2024 06:01 PM - edited 01-07-2024 06:03 PM
Personally I recommend a physical card. Do NOT purchase it through PM itself as it could take weeks to get it. Contact a local Telus store in your area and see if they have one or Amazon
The reason I say physical is because if your phone breaks or needs to go in for repair, you can just take out the SIM card and put it in your loaner or spare phone. You WILL have to purchase a new eSIM card if your phone breaks or goes in for repair and will cost more in the end. Just my opinion.
