02-20-2024
02:30 PM
02-20-2024
03:09 PM
computergeek541
I can't send group texts and I can't send pictures via texts. This just started 2 weeks ago. I have always been able to send group texts and pictures before.
02-20-2024 02:45 PM
if it is an S7, you might be affected by this:
Try Reset All networks or Reset network settings to get the latest APN
If issue persists, you can make a manual update, here are the old and new settings
Old settings:
APN: sp.mb.com
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
02-20-2024 02:43 PM
I have an android Samsung S7. I have lots of data and it happens with wifi as well. I have checked all my settings. Phone repair people are of the mind that it is PM and not my phone.
02-20-2024 02:39 PM
not even when you are in Wifi?
it is a phone settings, not a PM service problem
are you using iPhone or Android? check with settings on the message app
if Android, you can try to clear cache or try another app
or easier, you can try your sim in another phone
02-20-2024 02:34 PM
@languagemaier Did you accidentally turn cell data off in phone settings ? Do you have data left ? Or do you maybe have a data limiter set in phone settings
