Do I link my acounts
02-12-2024 02:20 PM
02-12-2024 02:37 PM - edited 02-12-2024 02:52 PM
If you sign into your self service account, you can change the email address to login by modifying your everSafe login credentials.
https://www.publicmobile.ca/en/ab/get-help/articles/eversafe-faqs
Edit:
Under profile section. modify your everSafe:
02-12-2024 02:27 PM
HI @Stu67
then it is easily, you can have PM support agent to find your old account back for you and update the email address . please submit a ticket with CS Agent here:
02-12-2024 02:26 PM
No somehow it forgot my email and I was using my phone number to login. So I made a new email acount but when I try to add my phone number it says there is an existing number
02-12-2024 02:24 PM
HI @Stu67
if you have two accounts and you want one login, then sorry, this cannot be done. Each account uses its own email to login and cannot be combined
But if you meant you have a new sim card and account and you need your old phone number back, then give us more details, it might or might not be doable.
02-12-2024 02:22 PM
you can't...every account is unique with it's own account number, phone number and email address.
