where to find 90 day plans ?
bill2009
I use the $25/mo 3g speed plan most of the time and the $50 us plan for 3 months of the winter.  A 90 day subscription would be fine with me if it cost less.  where do i find the option?
will13am
@bill2009 , you should see all available plans including 90 day options in your online account.  If you go to the plans and add-on tab and select plan change, all options will be shown.  Generally, 90 day options are available for the more expensive plans.
Dunkman
@bill2009
There are only a few 90 day plans.  At present time, 90 day plans do not include the $25 or $50 Canada US plans.  There are only three 90 day plans right now.
https://www.publicmobile.ca/en/ab/plans
@bill2009  The $25 plan doesn’t have. 90 day option . Only certain plans do the ones that mentioned it in the description you have to select it from the subscription add on page on you account. Select it confirm for next renewal and you will get option for 90 day then confirm change for renewal
