01-09-2025 01:49 AM
01-09-2025 11:40 AM
hi @Konica
are you able to login My Account and check your account status? Maybe the account was suspended for payment problem?
or Reboot the phone and Reset Network Settings. And if you have another phone around, test the sim card in another phone
if same, then you will need support agent to check. Please submit ticket by direct message:
01-09-2025 11:39 AM
reboot the phone and test again
and ask PM to check the account. You will need to message them here
01-09-2025 11:37 AM
Only wifi is working, I am not able to send even text messages
01-09-2025 06:36 AM
@Konica you mentioned that calls and data are down, does that mean that you can send/receive texts? Do you have wi-fi connection? Please share a little more info if you can
