Data
JuanitaR
Will I have data if I’m travelling overseas?
JuanitaR
Thank you.
JuanitaR
Thank you.  I thought so.
HI @JuanitaR   You cannot use your data outside of Canada
If you are going US, you can buy data add-on, but cheaper to get local data prepaid sim or eSIM travel package
If you are going other counties, no roaming option
@JuanitaR
No.  PM does not offer roaming for countries other than Canada and US
But even US, you need to buy data roaming add-on to get the service
@JuanitaR  No PM only works in Canada and the US with roaming add on best to get local SIM card in your destination
