Ulofon27
04-18-2025
03:01 PM
04-18-2025
05:31 PM
computergeek541
Recently I bought a new Ulefone 27, I can received and make calls, but I'm unable to use the mobile data, I mean, i can't see anything on internet trough the phone. But I can use as a hot spot for another devices, the APN parameters seems to be good, I just want verify if the information is correct in the APN
Phones
04-18-2025 03:04 PM - edited 04-18-2025 03:05 PM
hi @Tarkus52
Reboot phone and Reset Network settings first
if still does not work, try update APN,
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
04-18-2025 03:03 PM
Try Reset Network Settings and try data again
