04-17-2025 01:11 PM
I purchased a 1GB data add-on on April 14 and today (April 17) it disappeared and I received a text saying that I used 100% of my data. On the website, it doesn't show my add-on anymore, but in payment history it shows that I purchased it and in data usage it shows that I only used about 80MB of the 1GB? Tried restarting my phone as some suggested, but that doesn't work. Refresh button also doesnt fix it.
thankyou
04-19-2025 08:44 AM
@joshzw Settings - Cellular - scroll down to the list of apps, if you don't see all of them you might want to select "Show All". That will show you which apps are using data. To keep it current you need to select Reset Statistics at the bottom. Also you may want to disable WiFi Assist if enabled, just below the apps list, to stop the phone using data when it doesn't get a good wifi signal. You can toggle off any app to stop it using cellular data.
04-19-2025 12:39 AM
Odd, now it says i used 901MB yesterday morning when I don't remember doing anything that data intensive. Any way to check where I used that data? On iPhone
04-17-2025 04:33 PM
@joshzw wrote:It does show the purchase and the 80 or so mb that i used before it bugged, just doesnt show up under usage breakdown now as it should
The usage breakdown usually updates only one per day. In the early morning. So, what you see in your account for data usage is not up-to-date. It will update coming up near midnight or early in morning tomorrow.
If you don't see the add on anymore, that usually means that you ran out of data. The warning texts is usually not wrong.
04-17-2025 03:03 PM
04-17-2025 03:00 PM
Both, the data pretty much just disappeared
04-17-2025 01:25 PM
@joshzw Just to clarify, the data is not working or its just not showing on the website?
04-17-2025 01:19 PM
Click on Usage History, your purchases should show there. Refresh again.
04-17-2025 01:18 PM
@joshzw wrote:I purchased a 1GB data add-on on April 14 and today (April 17) it disappeared and I received a text saying that I used 100% of my data. On the website, it doesn't show my add-on anymore, but in payment history it shows that I purchased it and in data usage it shows that I only used about 80MB of the 1GB? Tried restarting my phone as some suggested, but that doesn't work. Refresh button also doesnt fix it.
thankyou
If you feel this information is incorrect, you can create a ticket and ask a CS Agent to investigate.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
