05-26-2023 02:57 PM
As the Rewards is changing to the new Points, do I have to activate the Points program manually in order to receive the points? Has the Rewards program already ended?
Rewards
05-26-2023 03:04 PM
@loyee wrote:Thanks for reply.
The new website interface is a little confuse to me. I have a little difficulty to look up my old Rewards! 😕
So that means I should not do anything, right?
Yep. Do nothing to stay on the old rewards system.
05-26-2023 03:03 PM
Thanks for reply.
05-26-2023 03:01 PM
HI @loyee you are lucky if you are still on the old reward. No force migration to the new one. Stay
05-26-2023 02:59 PM - edited 05-26-2023 03:05 PM
@loyee If your on old rewards you get to keep those rewards if you change plans , new activations are on the new Points program …. So long as you don’t not choose to switch to points you can freely change plans and keep old rewards
Add typo
05-26-2023 02:59 PM
@loyee If you have had your account prior to the new points program, it's advisable to keep it and not migrate to the points system. If you choose to go to the points system you do have to opt in.
05-26-2023 02:58 PM
@loyee NO
If you are on the OLD rewards, you can stay and no need to change. and DON"T change. the old one is much better
Only those on new activation, they have no choice but to be on the new Public Points
