Data usage in the US
aakhtar98
I have the US-Canada package with 60GB. I came to the US today and my data stopped working. I also got a message that said I had to pay extra for roaming. My package had 60GB data in both countries with unlimited messages and calls. Do I just turn on roaming so I can use the data part of my package or will I have to pay extra?
Austin_0005
I had the same data issues recently while in the states but I didn’t check here until now.
fixin1
@aakhtar98 - If your plan says "Data within Canada and the US" it should work, so please follow these instructions:
  • Use T-Mobile on 4G / LTE and sometimes 5G. Also AT&T on LTE.
  • Enable data roaming
  • If that does not work, resetting network settings may.
Also that is a normal SMS sent to all when they roam in the USA. No worries to buy a USA roaming package.
If nothing, please contact CS_Agent:
Submit a ticket via Chatbot:
⬇️  Click the link for an Agent * ⬇️
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST.  You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your community mailbox by clicking this link here: Mailbox
Chalupa_Batman
Hey @aakhtar98
Just go into your network settings and turn off automatic and pick T-Mobile then reboot. You should be up and running!! Also yes, turn on data roaming. Remember, Public Mobile is PREPAID... meaning you've already paid for the service. No hidden or extra fees.
@aakhtar98
yes, you need to turn on Mobile roaming data on your phone
also, make sure you connected to T-Mobile or AT&T.  You can try manual connection and test both networks and see which one works.  And best to change your network mode to 4G or LTE and not 5G
