01-14-2022
03:11 PM
01-15-2022
12:05 AM
computergeek541
Hello i have 2 gb of data and I have used 1 gb of data and cannot access any internet. Can you please look into this when possible? Thanks!
03:27 PM
01-24-2022
06:12 PM
Luddite
@DylanSinnicks First try rebooting the phone. You should also log into your account and make sure you see the data line on the overview page under My Data/Add-ons. If that line is missing, then it's possible you've depleted your available data and will need to purchase data add-on to tide you over until renewal.
It's also possible that you've set a data limiter on the phone. Reminder that data usage on your phone, may not be accurate as PM plans renew every 30 days and you would need to sync your renewal dates on your phone each cycle.
(no data left ........ Luddite)
01-14-2022 03:14 PM - edited 01-14-2022 03:14 PM
This is more likely to be a device issue. Have you checked your phone's APN settings already? You will also want to make sure that your phone's "data saver" feature is turned off.
Would you please post a screenshot here from your self serve, to help us better identify the usage history?
01-14-2022 03:25 PM - edited 01-14-2022 03:26 PM
go sign in to Self-Serve, to review your account, history usage if you have any leftover!!
for more information about Managing Your Data Usage visit Here link to save your data...
and turn off background data, to save your data.
when your data limit used all, is will be off until next renewal cycle,
at public mobile 30 day Prepaid Service No fees extra charges...
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone click Here link,
or visit Here link,
APN Settings On Android device click Here link,
Ensure you have the correct APN settings by visit Here link,
Select the brand and model of your phone,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
try to check update your device,
you can try to test your SIM card in another device to you know the issue from SIM card network or your device issue.
if you can't fix it you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to them can solve, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent,
Good Luck...
01-14-2022
03:27 PM
01-24-2022
06:12 PM
Luddite
01-14-2022 03:50 PM
@DylanSinnicks best to confirm your usage locally first.
Are you on Android? if so, there is a Data usage page, just set the start date to your PM cycle start date and it will show you your data usage and which app used the data
01-14-2022 04:14 PM - edited 01-14-2022 04:57 PM
I could not see any data but my phone tells me I have only used 1 gb and it stats here that I have 2 gb. I have reviewed my emails and they have stated that all may data is used up review photos attached
now this could be just a data issue but I need someone to confirm because it just saying I used up all my data on the website.
01-14-2022 04:45 PM - edited 01-14-2022 04:46 PM
Can you please edit your second screenshot from your post and your image library in your profile please as it contains more info than you intended to reveal. Click the 3 dots at the top right corner of your post.
01-14-2022 04:58 PM
OK done thanks!
01-14-2022 04:59 PM
@DylanSinnicks You need to ensure the usage being reported on your phone matches your PM 30 day cycle. Re-enter the start cycle on the phone to the same date as when your PM 30 day started. This should give you a more accurate data usage report, although it will not match exactly.
If your data line is missing on your overview page (self serve account), then you've used up your data already. You can purchase more data by clicking the Purchase Add-ons (right of My Data/Add-ons) and follow prompts. Reminder buying add-ons is a two step process, first add funds and then go back and purchase the applicable data.
Add-on data cost is $15/1GB but this add-on doesn't expire and any remaining data (once renewal resets your plan data) will stay on your account until completely depleted.
01-14-2022 05:01 PM
If self serve is indeed showing that your 2GB is all used up then this is decidedly a phone issue. Your own screenshot shows that you have used up 1.34GB just since the 1st of the month (so in the last 2 weeks). You likely used more in the time between when your plan renewed last month, and the 1st of this month.
My best suggestion would be to hunt down the app that is using more of your data than you want it to. You can do this within Android's data manager reports.
