03-19-2020 05:18 PM - edited 01-05-2022 10:00 AM
Hello,
Wondering if there was a way to check what speed (3G, LTE etc) I have with my current plan. I can't seem to find that detail anywhere when looking at my current plan on the website.
Thanks!
03-29-2020 04:55 PM
@helenhelen wrote:When did Public Mobile remove access to the 4G LTE plan? :catsad:
@helenhelen Fall 2017. Longer than I first thought before checking: https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/Share-Your-3G-Real-World-Experience/m-p...
03-19-2020 09:24 PM
03-19-2020 07:32 PM
03-19-2020 05:46 PM - edited 03-19-2020 05:46 PM
Looks like I'm on LTE. Probably have had this plan for a couple years now...
03-19-2020 05:40 PM - edited 03-19-2020 05:41 PM
@ijeung wrote:Hello,
Thanks!
@ijeung When you access your selfserve on the first page under the My Data and Add-ons section it will show your current data info. If it does not say 3G then your speed is LTE.
03-19-2020 05:28 PM
@ijeung PM's speeds are 4g LTE throttled to 3 mbps And 3g unthrottled max between 21 mbps and 42 mbps depending on the 3g band connected to.
03-19-2020 05:26 PM - edited 03-19-2020 05:27 PM
Which plan have you subscribed to and when ?
Click My Account / Plan Details
