04-10-2024 09:15 PM
Why am I not receiving the Eversafe ID code that was supposed to be sent to my phone number?
10-21-2024 03:19 PM
04-10-2024 09:19 PM
@rai79 - Did you just port in to Public Mobile? Did you just recently change your phone number?
If you just ported into PM recently - please see if you missed replying YES to your old providers text.
If you changed numbers recently - you may have to check your EverSafe ID to see if it hasn't changed yet.
Also click on "Didn't Get the Code?" and select "Send as Email." If there is no option - try hitting "Resend Code" or trying in random numbers 4 times and see if the email option appears.
Otherwise - please contact CS_Agent for help:
⬇️ Click the link for an Agent * ⬇️
If the link above doesn’t work correctly, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
04-10-2024 09:18 PM
Hello,
That is an occasional issue upon porting to Public Mobile. You won't be able to authenticate your identity without the code sent to your phone number. I would suggest submitting a request to customer service by writing to them using the following link:
Please be sure to explain the issue to them. They will respond to you in your community inbox so check it from time to time. (Little envelope icon on the top-right of this page).
04-10-2024 09:17 PM
Click on Resend Code or Didn’t Receive Code and have the 2FA Code sent by email.
04-10-2024 09:17 PM - edited 04-10-2024 09:18 PM
Hey @rai79 Try this.
Can’t get the 6 digit 2FA code to your phone?
First, sign into your account at www.publicmobile.ca and use the email you signed up with and the password. If it asks you for a 6 digit code, it will say at the top left CONFIRM YOUR IDENTITY.- Enter the 6- digit code sent to *********. But it’s not working!!! As you see by the screenshot below, 1. Click the This is a trusted device. 2. Didn’t get the code? Click on that.
Then, the next window that pops up is this.
Click on Send email. Here it will send you the 6 digit code to the email you registered with. This step is very important. Do not just copy and paste. Enter each digit using your keypad.
You should now be able to get into your account.
Created by Chalupa Batman
If you're still having issues, please create a ticket.
To Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
