Code via text
Jon1980
I tried to change my password, and it said it sent a code. The phone number the code went to does not coincide with my phone number. How do we change this so that it uses my phone number?
robm54
As originally mentioned, this was previously fixed by an agent after my submission of a ticket.
@robm54
you can try again using a different browser or browser with Incognito mode
and try using the app as well.  After you logged into the app, go to Account page, click "Manage Login (Secured by EverSafe)"
robm54
Both conditions met but still didn't allow me. Was a new functional activation with a successful just ported in number, and eversafe was holding on to originally assigned number from the initial activation
@robm54
you cannot change the phone number?
make sure you can only change to a Canadian phone number, and the number cannot be tied with another EverSafe account (ie, one phone number for one EverSafe account)
robm54
Curious to know if Softech's solution was successful as I tried that method for exactly the same problem and after logging in, the app wouldn't allow me to change it. I ended up having to submit a ticket to get it done.
@Jon1980 first try to get back into My Account then you can change the phone number to receive the code.
to get into My Account now, use email to receive the code.  On the screen it is expecting you to enter the code, click Didn't get the code? or  Resend code and then choose Send email
Once you logged in, go to Profile page, click Manage EverSafe id, and update the phone number there
https://myaccount.publicmobile.ca/en/account/my-profilehttps://myaccount.publicmobile.ca/en/account/my-profile
if you cannot receive the code via email and cannot login, ask support to help
 Private message CS Agent at:
