Phone for seniors without text ability
Dorothea99
I bought a RAZ Memory Cell phone for my 99-year-old mother-in-law.   It keeps things simple on the user end, and doesn't accept texts.  Is there any way to verify the number?  It's definitely working to receive calls.
You meant the RAZ Care app? I doubt the mobile provider will cause the problem. But try putting in another sim card from a different provider
Or do you have another phone to install the RAZ app and test the PM sim !
hi @MargaretAnne what is RAZ program? what error you got? does it work with wifi?
MargaretAnne
Me again.  There is no ability to text, but I bought a second phone for my other Mom.  Now the RAZ program won't load on the Motorola phone provided.  RAZ insists that it is a problem with her SIM card, but it works in my phone and the phone rings, just with no way to answer on a black phone.
SeniorCitizen
Does the phone need a texting APP added to it?
@Dorothea99
Try rebooting the phone with the PM SIM in the phone by powering off then back on.
I assume you picked a new number for her. Check the phone setting to see if the number Is shown. I am not familiar with this phone but it should indicate Public on the top of the phone.
hairbag1
@Dorothea99
when you activated the new Public Mobile sim, you must have either selected a new number or initiated a port of old number in to new account. Try calling someone nearby and view the call display to see her number.
