My Text only plan?
michaelwei1
I have a basic $13 plan, I just noticed I don't have 60 minutes local talk time anymore, just 50 text messages monthly, was there a change in my plan? Can PM just remove features on my plan without notification?
Phil_Adelphus
@michaelwei1   If you don't know how to edit out  your personal details, it's the little v in a circle top right of your post, that will access the edit function.
CSA_PM
Customer Support Agent
Hi @ michaelwei1
Let's continue the conversation privately.
Please click on the link below to find the emails to your inbox.
@michaelwei1  I have this plan too if you check on the public mobile app tap the “usage breakdown “ button and it will show the 50 mins you should have with the $13 plan
CSA_PM
Hi @ michaelwei1
We can have a look together.
I sent you a private message — you can reply by clicking this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
Regards,
Denise CS_Agent
hairbag1
@michaelwei1
if you need minutes now...consider getting the 500 minute Canada wide calling add-on for $5 (or Points if you have them). When your regular plan minutes are used up, then the add-on minutes take over.   Those add-on minutes don't expire until you use 'em up...even if that takes several month or more. Actually a good add-on to have added to your plan with limited calling time.
correction
Chalupa_Batman
I'm not sure of the plan itself but if you feel it was changed and not notified, you can create a ticket and have a CS Agent look at it.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
