Disable Voicemail
MikCla
Is there a way my account can have Voicmail totally disabled and never cut in? I would prefer that callers get no answer rather than the ability to leave a voicemail.
hi @MikCla
you cannot really disable VM, but there is a workaround
You can do this:
dial into your voicemail and log in with your PIN.
In the main menu, press 3 (manage greetings),  then 4 (manage extended absence greeting),
then 2 (record a new extended absence greeeting) and record a message that indicates to your caller you are not accepting messages.
Then press 4 to turn on extended absence
Finally, press 5 to dissallow anyone to leave you a message.
Sorry, but voicemail cannot be completely disabled.
