Account Cancellation
xe007
I moved to the USA.
Phone verification does not work because I have a WHOLE NEW PHONE and its sending the code to my old number ending in 9100.
I need an agent because I cannot login.
Xavier
xe007
Thank you. Brilliant and it sucks that we have to use mind games to wing around things.
xe007
Thank you will try that!
HALIMACS
Another way to get the code, @xe007 , is to tap "Didn't get the code?" and there should be a prompt to have the code sent to the registered e-mail address for the Public Mobile service.
Then, you can log into the self-serve account, and turn off the Subscription status under Manage My Subscription.  This way, your payment card won't be charged on the next renewal date.
xe007
I cannot use option 1. It want me to log in after I hit contact us in Chatbox.
Chalupa_Batman
@xe007 wrote:
I moved to the USA.
Xavier
Hello @xe007
You can also click on "Didn't Get Code" which should give you the option to send it to your email address. Then you can go into your account and turn off autopay. Give that a try.
HALIMACS
@xe007
  1. Use the ticketing system by clicking here , then Contact Us,  or
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
