a month ago
I've reset my phone, tried my sim in another phone as well, but I cannot send or receive SMS, as well as phone calls.
Can someone please check my account and make sure everything is good ?
a month ago
It sounds like there might be an outage in your area so check outage map:
a month ago
did you try Reboot phone and Reset Network Settings?
And if you have a physical sim, test it on with another phone
But if issue persists, you will need Public Mobile to help. Simply open ticket with PM using Expert Messaging using this link: https://expert-messaging.publicmobile.ca/guest/chat/
(Use your Community account to login. If you don't get the 2FA text, click Didn't Receive code or Resend code and choose to receive via email or voicemail. But if you still cannot get the code, then use another email to create another Community account to open ticket )
PM will reply you via Expert Messaging between 9AM-10PM EST (Mon-Sun)
(for help with Expert Messaging, check here: https://publicmobile.ca/en/get-help/articles/expert-messaging )
a month ago
nope, Data not working either.
a month ago
hi @LarryS60
does data work?
check if any outage in your area:
https://www.telus.com/en/on/outages
Also, Reboot your phone and reset network settings and test again
if same, ask PM support agent to check and help.
You can submit a support ticket right at My Account and PM app using the Expert Messaging in one of these ways:
Support agent will reply within 2 to 4 hours. You will be notified via SMS/email or monitor here:
Remember: Support hours of operation: 9 AM to 10 PM ET
a month ago
This just randomly started yesterday out of nowhere.
