12-02-2024 06:20 PM
On Nov. 27 I changed to the Can/ US /Mex plan and also changed my credit card. On Dec. 01 it billed me the rate for my old plan on the old credit card.
12-02-2024 06:43 PM
Thanks I sent in a ticket.
12-02-2024 06:26 PM
No just charged once at the rate of the old plan on my old credit card.
12-02-2024 06:23 PM
hi @Mike116
so, they charged you twice?
Can you check agian? It could be just a browser cache problem. Please try again using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in)
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
