3 weeks ago
Hi, I want to change my subscription on the next renewal date, but my account is not offering me all the possible subscriptions. I was originally on a 23 per month plan, I changed to a 35 per month plan for a trip to the US, and I want to change back next month to my original Canada only plan... but when my account shows the possible plans, the 23 or 25 per month options aren't available. Thanks.
a week ago
3 weeks ago
Oh, so some customers are more special than others?! Not very Fair, is it!
3 weeks ago
@willq wrote:It seems thatPM only allows you to upgrade subscriptions, no downgrades.
That isn't correct. Plan price downgrades are still available to many customers, but not all customers. Each customers will need to check the individual account to see which plans are avaialble.
3 weeks ago
It seems that PM only allows you to upgrade subscriptions, no downgrades. This sucks!
3 weeks ago
Who knew they would pull such a lousy trick. Will be looking into other providers. Thanks for the message.
3 weeks ago
Unfortunately, there are a tons of posting about this problem. You should have checked on this Community first before switching plans.
Lots of knowledge here from members on this Community.
3 weeks ago
Well, that's a lousy trick. That should've been made clear before I made the switch. Thanks for the info.
3 weeks ago - last edited 3 weeks ago
Lower plans then what customers currently have are not available to them anymore. You can upgrade only.
There might be cases where customer can see and downgrade to lower plan when logging in but I have not heard of such case yet.
3 weeks ago
this is not unusual, PM system only gives you some choices to plan and not all. They are doing this for couple months already. But do you see a $29 plan? maybe change to that
