01-30-2025
11:17 PM
01-31-2025
07:45 AM
computergeek541
I use my friends link When signing up, but it does not appear that it worked. I did not get a $10 bill credit and my friend did not get the points. My friend reached out to CS_agent and they advised I could still add the code, but I’m not sure how.
does anyone know how I add the referral code now?
01-30-2025 11:19 PM
whomever activated the new PM account should message Customer Support and ask to have the referral code added. Click the orange bubble on bottom right side of page to start that process.
01-30-2025 11:19 PM
@The_dit it can typically take up to 72hrs for the $10 credit to appear in your account. If you have waited this long and it's still not there than you will need to reach out to a support agent (since you are the one that tried using the code). The agent will be able to add it for you, I had to do the same for my wife. Link below:
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
