04-23-2025 05:36 PM
I went through the whole process on my phone with your app and it asked me to confirm my identity with a 6 digit code sent to my email but nothing was sent. I asked to resend the code 3 or 4 times no luck
Also I spoke to an agent and they said I did not link by SIM card to my phone number......either way I don't have access to my phone and it is not working.
04-23-2025 06:28 PM
Hi @ I-Claudius
I will send you a private message — you can reply by clicking this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
04-23-2025 06:24 PM
I did not have the account number so it gave me the option of the IMEI number. I entered that and then it asked me to click the number and it was contacting my old provider "Telus" and now it has come back with "Subscription not Activated" Sonething didn't go right when activating your subscription. Click below to contact a customer support agent.
04-23-2025 06:21 PM
hi @I-Claudius
i think you were using the app as it asked you about the phone number details. However, you shouldn't be enter IMEI, you should be entering account number
so, did you get a text from your old carrier for your approval to port? did you reply Yes? you need to reply within 90 mins
04-23-2025 06:04 PM
yes, it looks like you didn't use the app. But anyway, to sort thing out, please use the link in my post above to ask PM to help
04-23-2025 05:57 PM
Also it never asked me to link to my phone number
04-23-2025 05:52 PM
did you use the web to start subscription and then after payment, you were asked to use the app to complete the activation?
honest, I don't think your activation was completed. Please message CS agent and have them to help
04-23-2025 05:50 PM - edited 04-23-2025 06:18 PM
I believe it was, I got to the part where I entered my phone number and IMEI number and it was contacting my old provider when it said something went wrong. Contact support
04-23-2025 05:42 PM
Hi @ I-Claudius
Thanks for reaching out. Is the subscription already activated?
04-23-2025 05:40 PM
hi @I-Claudius
did you try the PM sim card? can it make calls? does data work?
and did you request porting in your number? if you see the confirm identity prompt but didn't get the text , and if you requested porting, the text would have sent to your old carrier's sim card as the port is not done. if you request porting, put the old sim back and check if it got the text
04-23-2025 05:39 PM
you already talking to agent?. then you have to ask them to check and link the sim card number back for you
or use this link to open ticket with PM
