SIM card
04-21-2025 06:05 PM
Hello, My current plan is $15 per month for 250MB data at 3G speed. If I am going to upgrade to one of the 5G plans, can I still use the current SIM card? Thanks.
Plans
04-23-2025 06:35 PM
self solution removed
04-23-2025 01:44 PM
Thanks.
04-22-2025 10:35 AM
All you have to do is change the subscription plan and wait for the nexr renewal date or you can renewal the same day. Previously I was using 4g now i am on 5g.
04-22-2025 08:54 AM
The question was already answered the previous day: unnecessary repetition
04-21-2025 06:36 PM - edited 04-21-2025 06:36 PM
@Yunyin So now you know you can use the same SIM card for any plan but do note if you change to a 5g plan or any plan from your current $15 plan you will no longer be able to get that $15 plan again . So if you just need 5G / roaming plan for short time it would be advantageous to just create new account with desired plan using your refferal code from your original account and reward both accounts for the time being . But if you don’t want the $15 plan anymore and just need more data on the regular then it’s no loss
04-21-2025 06:21 PM
Yes, you can use the same SIM no matter which plan do you chose!
04-21-2025 06:15 PM
Same sim card will do
