Change of plan
marceln
i have a plan with public mobile (1G); i'd like to take the offer you have, 4G for 24$. what should i do to avoid cancelling my account and move out .
golfball
There is a way, if customer service makes a special exception for you, but it's up to chance whether they will do so.
I think PM will have to have a serious discussion about their handling of these Boxing Day plans. Causing people to leave, upsetting existing customers and overwhelming customer service agents.
@marceln wrote:
but i keep my number?
Hi @marceln
no you don't
only way to get those plan is to port out your number to another provider, then you activate as new account and port number back in.  Please note you will loss all rewards you have with you at this point as well
marceln
marceln
there must be a way. can i create new account and ask for new sim, but keep the same number (no porting).
TheSterlinger
You can see if you like any of the other plans then you can choose one of them other then that there’s nothing you can do to get those plans.
@marceln  Sorry the 4GB for $24 is a new activation only plan , not for existing customers
