Cant receive phone calls or text messages.
WKFord
Samsung A10
Problem just started, I can send texts and make calls,  internet works , but cant receive texts or calls.   Calls just go straight to vm.
Have restarted, and taken the SIM card out but that doesnt fix the problem.
36 REPLIES 36
WKFord
Have rebooted by power off and that doesnt help.
@WKFord
Try rebooting your phone by powering off and not restart the phone.
Contact a CS_Agent if it didn’t work by creating a ticket on SIMon Chatbot (bottom of page) or private message (envelope icon above) them.
@WKFord
which province and city you are at?
did you try your sim on another device?
try to change the Preferred network type to WCDMA Only
LoveNature
Hi @WKFord
try to select 3G network and reboot device. or insert your SIM card in other device.
@WKFord  Also can try putting your preferred net work to 3G and see if that helps
hycm53
@WKFord wrote:
Samsung A10
@WKFord wrote:
Samsung A10
Try reset network.
