09-07-2023
07:18 PM
09-08-2023
09:49 AM
Dunkman
09-08-2023 07:27 AM
@Nga2 wrote:Phone not compactible. Have subscription but no service since September 3/23
@Nga2 are you also @Theresacm , or are you different situations here?
@Nga2 did you ever have service, and service just stopped? How do you know the phone is not compatible? If you try the SIM card into another phone does it work?
Public Mobile operates on HSPA, 5G, 4G LTE, and LTE Advanced networks.
Is your phone blacklisted, locked to previous provider, other...? More info would be helpful please for us to help.
09-07-2023 11:02 PM
@Nga2- What is the make and model of the phone?
09-07-2023 10:59 PM - edited 09-07-2023 11:02 PM
@Nga2 @Phone not compatible with eSIM or PM if eSIM you can just get a Physical SIM card and ask support to SIM card swap the number for you . They may even credit you the cost . Please reach out to support and see what they say
send a private message To CS_Agents click
VVVVV Link below VVVVV
09-07-2023 10:57 PM
09-07-2023 09:08 PM - edited 09-07-2023 09:10 PM
You can simply go to a Freedom store or contact them by phone and supply the IMEI number by dialing *#06#.
Freedom shouldn’t charge you to have it unlocked.
Once unlocked, you can use any carrier SIM including PM.
09-07-2023 07:30 PM - edited 09-07-2023 07:52 PM
Is the phone locked to Freedom? Every phone can be unlocked.
Public Mobile is a prepaid service. Typically there are no refunds.
09-07-2023 07:27 PM
@Handy1 why should they contact CSA? It is not public's fault if the phone is not compatible; so refunds would likely not be offered - don't you think in this case? And that may not even be the case here.
09-07-2023 07:25 PM
I'm always curious to know...what is the make and model?
What about real sms texts in and out? Calls in?
09-07-2023 07:25 PM
@Theresacm Please submit ticket with support you can use this direct mink
09-07-2023 07:25 PM - edited 09-07-2023 07:31 PM
@Theresacm - how old is the phone? Or what model as already asked.
Have you tried to Restart the phone. Turn it completely off, then restart it.
Try the SIM card in another phone to see if services work, maybe your phone is locked to Freedom. It that is the case call them to unlock it for you.
edit typos
09-07-2023 07:23 PM
Turns out phone only works on freedom. Activated the simple, but won't make call or get data.
09-07-2023 07:19 PM
What's the make and model of the phone? How far have you got?
