09-07-2023
10:46 PM
09-07-2023
11:04 PM
computergeek541
Can I get two lines activated at the same time on my iPhone?
My plan at PM still has over 30 days until renewal but I’ve used up all my data. Can I sign up for another line (use my own code) and get a random number (with eSIM) and activate it along with my old line (physical SIM) on my iPhone and use both lines simultaneously? Of course I will cancel my second line upon my old line renewal.
Joining Public
09-08-2023 02:13 AM
You can have 2 plans on your iPhone…one on the SIM and the other on eSIM.
But why don’t you download the TextNow app and pick a random number get the second line for FREE service through WiFi or connect your SIM data?
This is what I am doing!
09-08-2023 12:57 AM
That's a pretty complicated solution to a simple problem. Just buy a data add-on, or do what @dust2dust suggested and renew your plan early.
09-08-2023 12:43 AM
There may be some debate and YMMV on that. You will pay for the renewal up front but you might get rewards shortly after.
09-08-2023 12:32 AM
@Handy1 Is that what you would do? Adding a temporary 2nd line or early renewal and forfeit your rewards?
09-08-2023 12:24 AM
With early renewal, I would not get any of my rewards for the first cycle……
09-08-2023 12:17 AM
It's just dual sim. You can use one or the other for each feature. I set my apn on one account to only do mms. I set the other account to be the main data account. But you can tell it to use either account data too.
09-08-2023 12:14 AM
So how does that work? Having both numbers active and ringing on same phone. Can you identify which account/SIM card deducting the data usage from?
09-08-2023 12:13 AM
The $10 goes to the new account. You said you're going to cancel that new account. So you could get a couple 200mb add-ons and run out the new plan data and the add-on data and then cancel the account.
I would do the early renewal.
09-08-2023 12:08 AM
With new account, I save $10 in referral award assuming I can use that right away.
09-08-2023 12:05 AM
FREE wifi offered by business owners for its customers? What a concept!!! Unfortunately, North America ranks last in that category….. 1GB would last a couple of days if even 😞
09-07-2023 11:00 PM
You can also do an early renewal instead of a whole other account.
09-07-2023 10:59 PM
unless you're a real data hog...consider getting 1GB of data add-on for $15, unless you don't see 1GB lasting untl next renewal. Use more free wifi whenever available ?
09-07-2023 10:49 PM - edited 09-07-2023 10:50 PM
@Toxin You can have two separate accounts. only one number per account and it’s own email , but sure you can have one account on eSIM and a second account on physical SIM card and yes of course use your referral code for the second line
