Plan Cancellation and Refund
77suzyq
Decided not to go with Public Mobile.
Please refund/credit the initial payment of 45.20.
Sansan
The rule of thumb is no refunds.  But you can submit a request and ask.
Or if you are not able to sign in then use the link below.
hairbag1
@77suzyq
you need to message Customer Support to ask that...but don't be offended if the request for refund is denied. Public Mobile has a no refund policy.
slusagm
@77suzyq
PM is a prepaid provider and usually do not provide refund  They will only provide refund if there was issue with activation and the service was never used.   So, did you just sign up and never use the service?  But you can check with PM
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
