Canada-USA-Mexico plans
DeanaN
Can you confirm one hundred percent that there is no roaming charges for calls placed within Mexico and within the United States? When I clicked on the Canada Mexico USA plan and then clicked on the little details link it’s like they haven’t updated their terms and conditions and details because it doesn’t address the free calling in Mexico or the United States
golfball
Just to clarify extra charges are not a thing at Public Mobile. It's a prepaid service and if you haven't already paid for a feature then it simply doesn't work.
tonisage
There are no roaming charges.
HI @DeanaN
yes, I can confirm that.  The Canada-US-Mexico plan is to let you use the service in US and Mexico without extra charge, ie, the roaming is included in the plan
it is not just free calling, free caling is included, but you can also use data and text free in US and Mex like you are in Canada
@DeanaN  No extra charges for that plan it has roaming built into it and can be used in all 3 countries to call to and from using calling text and data no worries
