03-28-2023 03:19 PM
My friend has forgotten their login for their public mobile account and have run out of funds. They have bought a voucher for their account but can't call *611. What can they do? Can you add the funds to their account?
03-28-2023 03:51 PM
@ryguy11 wrote:tried calling 1-855-4PUBLIC and it also didn't go through
Try that number but use a different phone. When prompted, enter the 10 digit cell number that you're adding fund$ to.
03-28-2023 03:23 PM
03-28-2023 03:21 PM - edited 03-28-2023 03:29 PM
try calling 1.855.4PUBLIC and enter the phone number and then load the voucher that way
if that number does not work either, then open ticket with PM support. and ask them to load the voucher for you
Since your friend forgotten the My Account login, please choose PIN to validate if you use method 1 to open ticket. If he forgot the pin as well, please use method 2 below
1. Please open ticket via Chatbot (need access to My Account):
At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
03-28-2023 03:21 PM
@ryguy11 , there seems to be issues with 611 recently, try 1-855-4PUBLIC.
