Lost email login
courtcliff05
I need to make a payment to my plan as it's expired, i have a voucher i need to add to my account. I can't call *611 or 1-855-4PUBLIC, I can't log in to my account as it needs to verify that it's me through my email that I no longer have access to. But i can log in onto my community portal here. What can I do?
@softech wrote:
@computergeek541   any words from PM if *611 issue will be fixed soon? it has been long enough ..
sorry, I haven't read about any update
As you haven't been able to use the automated IVR to use the voucher, you'll need to regain access to your Self Serve account.  To change the e-mail address linked to your Self Serve account, please open a ticket to contact a customer support agent.  Open up https://widget.telus.tiia.ai/publicmobile/publicmobile.html and after opening that link, type "change self serve e-mail address".
@courtcliff05
you can probably open ticket with PM support to change your email address for login as well as ask them to help loading your voucher
If you use Method 1 below, please choose PIN for validation at the end of the ticket open step.  Or you can use method 2 for direct message
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
