11-05-2024 07:07 PM
11-05-2024 08:31 PM
Ok, it must be a local issue in Ottawa then - I submitted a ticket as well. 🙂
11-05-2024 07:33 PM
We have exactly the same issue. I created a ticket with the CSA.
11-05-2024 07:31 PM
I'm in Ottawa too and started only today
11-05-2024 07:28 PM
This is happening to me as well. I can't make or receive calls and can't reach my voicemail. I noticed it as of today but it may have started earlier (my last call attempted was on Friday afternoon, which worked at that time). I'm in Ottawa!
11-05-2024 07:16 PM
I can do all networking except making or receiving calls
11-05-2024 07:15 PM
Everything working except phone calling
11-05-2024 07:13 PM
You need to provide WAY MORE info that that if you need our help.
11-05-2024 07:13 PM
@Albertbreyes Can you confirm your account is active and not suspended ?
also check
Outage map in your area:
https://istheservicedowncanada.com/
if the account is active and no outage in your area and rebooting the device or network reset won’t help then please
11-05-2024 07:09 PM - edited 11-05-2024 07:10 PM
hi @Albertbreyes what phone you have? Does data work?
try reboot phone and try reset all networks on the phone
Also, try your sim in another device
and check My account to confirm if account is active
If nothing works , message support and ask them to check
