Phone calls issue
Ghyna
Hi,
I can't receive and make calls.  Is it a network problem? @members
7 REPLIES 7
Ghyna
Hi BKNS27,
Thank you for trying to help me. After many tries to restore my phone service, nothing work. I have decided to switch to another company. For now, everything is going well with the new one.  Good luck with Public Mobile!!
Ghyna
Yes, mobile date and messages work
@Ghyna
Try resetting the Network Setting on your phone and see if that helps.
hi @Ghyna
and mobile data works?
and does the phone connect after you changed the network mode to 3G?
if you have another phone, test the sim card in another phone and other try to test in another area
of course, if none of that helps, open a ticket with PM support as advised on my post earlier
Ghyna
@hTideGnow  thank you for your reply,  it's been like 3 days since I can't receive and make calls.
Chalupa_Batman
@Ghyna wrote:
Hi,
Hey @Ghyna
Check for outages in your area.
https://www.telus.com/en/mb/outages
Check your account to make sure your bill is paid up. You can also try resetting your network settings. If that doesn't work, contact a CS Agent to check on their end.
You can submit  ticket by direct message:
A Customer Service Agent will reply to your community inbox here:
HI @Ghyna
possible.  Which area you are at?
you can check the Telus outage map
https://www.telus.com/en/bc/outages
Montreal area has problem with Mobile data and voice
and try changing network mode to 3G, check if the phone connects in 3G and if you can make calls
last, ask PM support to check and refresh your account.  You can submit  ticket by direct message:
