Can't dial long distance have minutes
asmallamount
I can't dial long distance even though my account says I have 277 minutes left.
I get an error message.
Tried with 011 then number but it doesn't work.
I am trying to call Spain.
Please help public mobile, so very frustrating
9 REPLIES 9
dust2dust
The number may be configured with a leading zero. If so then try calling without the leading zero. Had you previously been able to call the same number?
Adding - just in case you are, don't use +'s in the middle.
Hi @asmallamount   that looks good
you have been caling Spain before and it works?
and you rebooted the phone?
did you try another Spanish number to call  just to confirm it is not that one number?
If you still cannot call, maybe submit a ticket with CS agent and have them to check
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
asmallamount
0 11 + 34   then number
HI @asmallamount what pattern you used to dial?
asmallamount
Nope tried new browser still says I have 277 minutes in add ons
asmallamount
It says cannot complete as dialed but I am using 011 then country code etc
asmallamount
I purchased these minutes and have been unable to use them, thanks for the idea though
Meow
Spain is included in long distance add-on and in all Holiday bonuses.
Confirm you really still have long distance minutes.
Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
Do you get any messages when trying to call LD?
HI @asmallamount
Spain is part of it and it should work
try reboot the phone once
if still does not work, login My Account again using Incognit/Private/Secret mode and see if you really have 277 mins left.  Sometimes it shows old usage if you don't use the special browser mode to check
