3 weeks ago
"50GB Data within Canada, the US and Mexico at 5G Speed" $35.00/MONTH
Simply, I want to confirm that with this plan, one can:
1. Roam within Mexico:
-Make outbound calls to Canada-wide mobile numbers (text, messages) without incurring long-distance/additional charges. Use the mobile data up the the limit without additional charges.
-In bound voice calls, texts, messages from Canadian mobile callers would be free of long-distance/additional charges if the inbound caller has unlimited Canada-wide calling (text, messages), that they would not be subject to LD/additional charges).
Is this the case?
3 weeks ago
@sheytoon ... That makes sense to me (now). Thank you.
3 weeks ago
It actually doesn't matter where you are. The person with a Mexican phone number calling a Canadian number will be billed the same way whether you are in Canada or Mexico.
You have to look at outgoing and incoming parts of phone calls independently.
3 weeks ago - last edited 3 weeks ago
@goink wrote:When in Mexico, will inbound Mexico callers (from CC +52) be charged Long-distance?
Nope...they're dialing your Public Mobile Canadian number.
added....if the caller has a Mx number and is calling your PM number while you in Mx...I think he'd pay LD charges as he'd be dialing a Cdn number. (Unless he has a plan that includes LD to Canada & US)
3 weeks ago
3 weeks ago
Correct, while you are in Mexico, you can call/text to any number in Canada, US, Mexico. You can also receive calls/text from any number in the world.
You can also use data and it will use up your normal monthly allowance. Just enable data roaming on your phone.
PM does not have surprise charges after the fact, as it is a prepaid service. If something is not included in your plan, it'll simply not work.
3 weeks ago
I have that plan and in Mexico right now. That plan works just as if I was at home. To dial Canada, you dial +1..then area code..then number. Text and data is just as if at home too. Make sure to enabled Roaming Data in settings. If you plan to travel to US / Mx..this is a great addition.
