01-22-2025 11:09 AM
I have a Canada us 30 subscription. but when i tried to make a call it, i get a voice message indicating i have reached my minutes limit, even through i have unlimited talk and text. any insight?
01-22-2025 11:39 AM
Thank you for the suggestions. I did try all of the above and for good measure, i also restarted the phone. It did not work. I have submitted a ticket to customer support. Hopefully they can sort it out. Thanks again.
01-22-2025 11:29 AM
The phone is probably cold 🥶. Try the suggestions and wait a few minutes and try again after 10 minutes. Sometimes it's just temporary glitch.
01-22-2025 11:23 AM - edited 01-22-2025 11:27 AM
@Farzi Try turning airplane mode on, wait a minute, turn it off again and try making a call. If that doesn't work reset network settings (not factory reset as that will wipe everything). If it still doesn't work contact customer service at the chat icon bottom right of this page and submit a service ticket. Edit you could also try restarting the phone. Also check for outages here https://www.telus.com/en/outages (I added that link to the wrong post before)
01-22-2025 11:22 AM - edited 01-22-2025 11:25 AM
@Farzi Can you receive calls? Again, where is it you are calling to, Canada or the US? What phone do you have?
Also check for outages https://www.telus.com/en/outages
01-22-2025 11:22 AM
within canada
01-22-2025 11:19 AM
Text messaging and data is working. I just Cannt make any phone calls. It tell me i have reached my minutes limit
01-22-2025 11:19 AM
@Farzi Are you trying to call within Canada, or somewhere in the USA?
01-22-2025 11:18 AM
I have Canada, US $30 plan. The account is active. I am currently in Canada. No fund is owing
01-22-2025 11:17 AM
Yes, I am in Canada. I rebooted the phone. The account is active and no fund is owing.
01-22-2025 11:14 AM
@Farzi Do you mean you have a Canada-US $30 plan, or do you have the $30 talk text and data roaming add on? Where are you calling to and from?
01-22-2025 11:12 AM
Are you currently in Canada? Did you reboot phone? Is your account active?
