01-31-2023
11:26 AM
02-01-2023
12:40 AM
computergeek541
All my calls are going to voicemail. Don't know why that is. I live in a metropolitan city. Any feedback?
01-31-2023 09:35 PM
HI @Kandrews so, the blocked calls and spam ended up blocked EVERYTHING? do you have the latest OS?
01-31-2023
09:17 PM
02-10-2023
02:29 PM
Luddite
Thanks. I will keep that in mind. I'm going to contact Samsung for any feedback on this issue. I went and turned off my blocked calls and spam on my phone app. It started working again. I even had my co worker call me from her cell phone and it worked again. But I will keep a close eye on it next month.
[self help to the rescue ............ Luddite]
01-31-2023 02:43 PM
Did this issue start up again after renewal? It's likely a provisioning issue again if that's what it was 5 months or so ago? Contact customer support to reprovision your Sim card again. If you find this issue continues to happen more and more often you may want to consider replacing your Sim card. When and if that time comes you can ask customer support if they will replace it for free or credit your account for the cost.
Click on SIMon below to submit a support ticket or if he gives you trouble send a private message. Read the spoiler in the linked post if you choose to send a private message.
01-31-2023 11:36 AM
Did you port your number? When? Did you follow porting instructions to the letter?
01-31-2023 11:32 AM
@Kandrews - now that I see some of your history, it seems you have had this issue before.
Did you submit a ticket with customer support back months ago? If so, what did they say or do?
If you did not, perhaps you need to send in a ticket to inquire about your account. Please advise what they say, if you don't mind, so we can learn what the issue may be.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
01-31-2023 11:29 AM
@Kandrews -more information would be helpful.
Are you new to public mobile?
Did you activate with a new or porting over number?
Did you have all your services working before this?
01-31-2023 11:27 AM
@Kandrews Did you just port your number ? Did you reply yes to text ? If so I can send you port team number private message
