Voicemail number not set
ramob
Recently switch from fido , when i press 1 , pop up shows voicemail number  'not set' , i tried setting it by inputing  +12265804001 it doesn't let me .
ramob
Tried that , it says 'Voice mail Number can't be changed' .
Thanks
@ramob
try manually update the phone number with :
( so basically drop the 1 after plus sign)
ramob
I did reset network setting multiple times , i didn't help .
Thanks
slusagm
Try Reset Network Settings
