08-25-2023 12:10 PM
08-25-2023 01:14 PM
If you explain the situation to the Customer Support Agent they'll be able to either manually apply it to your Account from the backend.
Alternatively, if they are unsuccessful I believe they'll refund you with 'Available Funds' in your Account so you can reattempt the Purchase again.
Within your My Account 'Payment History' does it shoe this charge as well or only on your Credit Card Statement?
I'd recommend using the App for everything, including Puschasing Add-ons to avoid issues like this.
08-25-2023 12:12 PM
HI @Cell_à_Noé
if you check the Payment history, does it show your purchase?
if you need PM agent to look into it and reverse the transaction, please submit a ticket:
08-25-2023 12:12 PM - edited 08-25-2023 12:15 PM
@Cell_à_Noé Try rebooting the phone first . If no luck please submit ticket with support to help fix
private message To CS_Agents click
VVVVV Link below VVVVV
add also note data add on now expire 30 days after purchase . Might consider switching plans for next renewal for the 20GB for $39 @Cell_à_Noé
