08-25-2023 11:57 AM
having trouble with porting my number. My current carrier says that information is missing from the request submitted by Public Mobile
08-25-2023 12:32 PM
@Rachelle192 did you use an IMEI to Port your number in or the Previous Providers Account Number?
08-25-2023 12:01 PM
thank you
08-25-2023 12:01 PM
HI @Rachelle192
you can call the Porting support team and they will re-initiate the process. I will message you the phone number. Check your Community inbox
08-25-2023 12:00 PM
@Rachelle192 I will send you number for live support to re trigger the port request for you . Private message
