04-07-2022 06:44 PM
I have autopay on, and have never had an issue until today when my payment was not received and my service was suspended. I logged in to make a payment, and it would not accept either of my cards, both registered to the same address. The notification I keep getting at the top of the page reads “unable to process transaction” and that it has not been approved by my card provider, though there is no issue with either of my credit cards. Any ideas? Please help!
04-21-2022 10:08 PM
@niravcadtech open ticket with CS agent and have them check for you and you have not done so. They will usually reply within an hour or two.
04-21-2022 09:56 PM - edited 04-21-2022 09:56 PM
Hi thanks for suggestions. I tried other option and entered amount but same issue. Autopay suddenly stopped working. They need to do something about it. @CS_Agent should consider it as priority as many people are facing same issue. I also removed auto pay which when i submitted ticket is their first attempt to pay from account during troubleshooting.
04-21-2022 09:49 PM
@niravcadtech @Moderator is not the real moderator, the one you want to look for is @CS_Agent but you should open ticket with them.. They won't action on it because you tagged it
Also, before you open ticket with them, just want to confirm if your account is Active or Plan Expired
If Plan Expired and your service is working , you can safely ignore it.
If Suspended, try to make a manual payment. But use the option "Other (Enter the desired payment amount)" instead of "Amount Due", that works better
04-21-2022 09:43 PM
I am facing same issue. @Moderator should do something about it.
04-07-2022 07:28 PM
Should be able to manually pay using other and then you can re-enable autopay going forward. Also don't know if there is a lingering effect from the the issues at the start of the month with autopay
04-07-2022 06:49 PM - edited 04-07-2022 06:51 PM
(sorry, for repost.. some of my earlier replies on this gone into unmoderatored items and I am so confuse)
04-07-2022 06:49 PM
HI @Kate-Mosher Do you still have a credit card on the system? if you do , try to make a manual payment using the option 'Other" and it could work that way
If you already deleted the card, you might want to wait an hour before trying to put another card on it. Trying too many times might trigger a Fraud lock
04-07-2022 06:49 PM - edited 04-07-2022 06:49 PM
@Kate-Mosher If there is an apartment or suite number leave that out and put postal code all in caps with no space.
If still not working then Contact support for assistance.
Contact customer service agents.
Open a ticket via
https://widget.telus.tiia.ai/publicmobile/publicmobile.html (faster response time
Type "ticket" > Click "Contact Us" > Select your issue > "Click here to submit a ticket↗
or send a private message to
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/224
In the interim you can go to a corner store or gas station like Petro Canada/ Shell and buy a top-up vouchers. Take a anywhere from 10 minutes to an hour to activate it's usually fast from those places by the time you drive home you're good to go. Dial 611 from your cell and deposit the top-up voucher.
Auto-pay has been iffy lately and it's never (for longest time) has been bullet proof. Many manually make a deposit the night before their renewal to avoid these situations.
04-07-2022 06:47 PM - edited 04-07-2022 06:49 PM
Could you try using different browser (Edge, Chrome)?
Do you enter credit card info Exactly as it is on statement? Do not enter apartment number (if any) and remove space in postal code. Sometimes all capitals make it work.
