01-15-2022 06:34 PM
Hi there. I would like to change my debit card I use for auto pay with a credit card, but when I remove the auto pay and try to set it again with the credit card, it does not allow me to enter new card and simply provide the one I entered at first place.
Besides, when I activate the auto pay, the free internet would not become activated.
01-16-2022 01:47 AM
@arashrocky : Can you get the specific detailed model number from that phone? Like ZD something or other? There are variants of this phone and some may work. But maybe yours is one that doesn't.
01-15-2022 10:48 PM - edited 01-15-2022 11:15 PM
Are you in big city in Ontario?
But , look like your APN is not setup properly still
Can you try to add new APN like this:
go to Settings – Connections – Mobile networks – Access Point Names.
From here press Add or the Plus sign at the top right and select New APN.
Then fill in the details your carrier gave you. Then press the menu button and press Save.
If you cannot, and you have not used this phone for too long , try to reset the network connection first (but you will loss you preset Wifi and you will need to resetup them up)
If still fail, and if you don't mind the trouble, backup your data and try to do a factory reset. But if you are trying factory reset , DO You restore your data right a way. Try the Data network first to see if it connects.
01-15-2022 10:44 PM
Ontario
01-15-2022 10:42 PM - edited 01-15-2022 10:44 PM
@arashrocky your phone does not have all the required bands for PM
And which province you are at?
For data (LTE), it should have B4 or B12 for minimum coverage, but you lack both of them
even voice (3G), it might not work great because it only has 1 of the 2 bands for voice
Do you have another phone to test out the PM connection?
01-15-2022 10:34 PM
right. I have not used this Asus Zenfone4Selfie with PublicMobile before. So from the moment I inserted the sim card into my phone, the seller showed that the mobile network is on and internet may be accessible as soon as i register for auto pay option using a credit card, which I made it according to previous hints.
01-15-2022 10:27 PM
@arashrocky tell us what model is your phone? Some are easy some are trickier
Again, Data NEVER works on PM before with your current phone, right?
01-15-2022 10:26 PM
I proceeded with the procedure you mentioned and found out that there is not an "APN: sp.mb.com" on my APNs. and there is not any option to create a new APN there. so what should I do?!
01-15-2022 10:23 PM
@arashrocky did you use this phone for Data on PM before? It suddenly stopped working or it never works on PM network?
what kind of phone is that ? brand and model?
01-15-2022 10:07 PM
go sign in to Self-Serve, to review your account,history usage any left data
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone click Here link,
or visit Here link,
APN Settings On Android device click Here link,
Ensure you have the correct APN settings by visit Here link,
Select the brand and model of your phone,
and try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
for android visit Here link ,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
*for more information about Managing Your Data Usage visit Here link to save your data...
and turn off background data, to save your data.
when your data limit used all, is will be off until next renewal cycle,
at public mobile 30 day Prepaid Service No fees extra charges...
01-15-2022 09:59 PM
the Public Mobile sim card is showing to have full antenna access, and I am able to have incoming and outgoing calls and capable of send and receive sms.
So I guess the problem should be around the mobile network configuration. My cellphone was set to prefer 4G type of internet network which I changed to 3G (as the bonus was advertising to provide 3G internet). Also, there are two Access Point Names which are "TELUS SP" and "Koodo". I chose either of them but still none gave me any internet access.
01-15-2022 09:50 PM
@esjliv wrote:@arashrocky - I would say you exactly found your solution!
Then the Accepted solution was not the correct one? LoL
01-15-2022 09:49 PM
Yup with visual and all, that is where you go. 🙂
As for Data is your Data option turn on in the settings of your device?
If so, and still not working, perform a Reset of your Network Settings:
iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
android:
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
If still not working after this, check the apn settings, see here: https://www.publicmobile.ca/en/on/get-help/articles?q=apn
01-15-2022 09:49 PM
@arashrocky Your data is not working. How about voice calls ? incoming and outgoing working? what is the account status? Active or Suspended?
Please check and let us know
01-15-2022
09:41 PM
01-16-2022
02:51 AM
computergeek541
Thank you for your comprehensive reply "S--S".
Honestly, within all the possibilities you mentioned, I realized that the "Manage my card" is only available below the "Make a Payment" tab in a small font size. and as "darlicious" demonstrated, the rest is just as the photo they attached. So I successfully managed to change the my debit card to credit card.
Having solved this card changing issue,I am working around to find out why the mobile data is not getting activated?!
(screenshot removed for privacy reasons)
01-15-2022 07:00 PM
Follow this method.
I just click on one time payment and in the middle of the page you can click on manage my card. Then I follow this procedure....
Follow this method when making a manual payment/adding a card to the account....only use the emboldened portion of the instructions if the payment card is already on file.
Once you successfully update your card do not attempt your payment immediately. Log out/in then go to make a payment to pay for your renewal. Otherwise if you were not suspended I would recommend a $1 test payment. Follow my further instructions for a successful payment to unsuspend your account.
Do not try more than two attempts at adding a card or payments ( successful or not) or you will continue to get this message. Wait at least 1 hour to try a third time another hour for your 5th try....and so on....and do not make more than 4 unsuccessful tries with the same card in a 24 hour period or you will trigger a fraud alert lock out requiring assistance from customer support.
Go to make a payment. Choose the "other amount" option and add $1 more than the amount owing and submit the payment. If that is successful go back to your overview page and if it does not say active click on the reactivate button. If that works log out and reboot. If that does not work and your payment is in your balance rather than showing $1 then go to the usage or plans page. Click on lost/stolen and suspend your service. Log out/in. Resume your service. Your balance should now be $1. Log out and reboot.
Or you can go to edit my profile and in the top right corner there is a reminder to update your credit card address "here".....click on that link to be brought to the following page. Employ the same method as in the spoiler.
01-15-2022 06:51 PM
Accepted payments(publicmobile.ca)
i suggest you close all Browser and do clear cache and cookies for any Browser,
and try open one Browser incognito mode,
or try it for a different Browser and open incognito mode,
how to open Browser incognito mode visit Here link,
how to clear cache and cookies and History visit Here link,
and use a Browser from your computer,is better
use Browser microsoft edge or chrome latest version
and just make sure your Browser is up to date update
sometime is the Browser is not update is give a issue.
how to update your Browser visit Here link,
and Restart your computer, is will help a lot,
and if you use a home internet take your power internet off for about
a 1 minute and put it back on,to refreshing your network.(if you needed)
and log in and re-entered your credit details,
just make sure your credit card number and your address match the same,
sometime your typing but is a one word or letter or number is a wrong or missing just make sure for it.
How To Update or Remove Your Payment
Follow these steps:
1. sign in to Self-Serve. Once signed in,
2. click on the ‘Payment’ tab,
then scroll to the bottom of the page and select ‘Manage my card’.
you will have the option to either select ‘Replace this card’, or ‘Remove this card’.
You will need to review and confirm this change to your account,
after you Add your credit card go back,
and if can't fix it you need To Contact Customer Support Agent by CS_Agent, and Explain your issue to them can solve your issue, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent,
Good Luck.
01-15-2022 06:43 PM
Once you have the new card set up for autopay, we can investigate the free internet issue.
01-15-2022 06:42 PM
@arashrocky wrote:Hi there. I would like to change my debit card I use for auto pay with a credit card, but when I remove the auto pay and try to set it again with the credit card, it does not allow me to enter new card and simply provide the one I entered at first place.
Temporarily disabling autopay doesn't cause you to lose any bonus data. I'm wondering if you've only disabled autopay but still left the old card on the account. You'll need to use the "manage card" option to first remove the old one before you can add the new credit card.
01-15-2022 06:42 PM
You can definitely add a new card to auto-pay, I just tried right now. Please try using a different browser, and post screenshots (not showing any personal information!) if you get stuck so we can help you further.
