yesterday
Hi there,
I am trying to choose between the
- $36 50GB CA/US plan (5G)
- $34 65GB CA/US plan (4G) *90 day sub
Does the PM network even have 5G speeds?
Is there much difference for speed on the PM network, between 5G & 4G?
*** I don't have a 5G phone right now, BUT will get one "IF" it makes a notable difference on the PM network
Thank you
yesterday
Lol, all this and I may just wait till Black Friday now... I'd be a bit shocked if they don't have anything at least as good as what's offered right now. Guess we'll see.
yesterday
@Chris_ Yes that’s a good point , and with Black Friday around the corner you never know what might pop up , currently have 60GB $34 30 day 5G plan . I will never spend more then $34 for any plan unless it’s true unlimited plan even then I would pay more then $40 for that . All comes down to what you need and what your willing to pay the more people that refuse to spend more then what they need carriers will take notice and rate plans accordingly is my guess
yesterday
I guess my next concern is...
As I've been told here by some, once you move your plan up in price, you may not see cheaper plans available to change down to ever...
That 65gb plan is actually a $45 plan *$34/mo on a 90-day sub
Maybe I'd be stuck in that ~$45 tier forever after that plan change?
yesterday
@Chris_ That’s marketing for ya throw more data on that you most likely won’t need to have you spend more all carriers are doing it . So unless you don’t have home internet I think you be hard pressed to use 65GB every 30 days or 195GB over 90 days but at $34 month you can’t go wrong . Hope one day we see true unlimited plans for $40 and we can all ditch home internet service
yesterday
Yeah, cuz in a way you may even be exceeding that 65/195Gb without any issue... I've never exceeded much past 10 to think of anyways... maybe got to 20 once, cuz I tried? But someday I may want to tether with my laptop sometimes, or if I'm on a road trip, I'd really be relying on that data...
yesterday
@Chris_ wrote:Oh...? K that's sort of a key point here.
Is the CAN/US 4G plan "unlimited" at lower speeds AFTER using up the 65Gb ?
Or is the "unlimited" at 512Kbs AFTER using the __Gbs only available on Canada plans?
Or is it ONLY the 5G plans that are not "unlimited" n lower speeds after the __GBs are used up?
Like I mentioned below @Chris_ nope. Once you use your 50GB in that 30 days, no more data for you unless you buy a data add which costs more money. Hence the reason having the extra 15GB is better value.
yesterday
@Chris_ No 4G plan is unlimited only 5G plans that are not CAN/US plans have 512kbps throttled data once the plans data bucket is exhausted
yesterday
yesterday
@Chris_ Unlimited data is only on non CAN/US 5G plans . Rest just have a data bucket and that’s it
yesterday
Data Usage is "Unlimited" on both plans, isn't it? Just the we only get the high speeds up to our 50/65GB Limit...?
yesterday - last edited yesterday
Just a thought....
$108 over 3 30 day payments. 50GB of 5G speed data x 3 = 150GB of 5G speed data - once you used your 50GB of data, no more data for the 30 day period.
$102 for 90 days x 1 payment. 195GB 4G data speeds bucket. You get it all at once.
So look at it this way. $108 150GB 5G speeds vs $102 195GB 4G speeds.
yesterday
@Chris_ In my experience it’s easier to get up to 100mbs of 4 g plan then it is to get up 250mbs of 5G plan . I find the 4G plans are more consistent in speed test then 5G
yesterday
It's the "up to" that I'm looking for clarity on from users experience.
Are customers actually seeing much higher than 100Mbps with their 5G phone on a 5G plan here?
Is the experience between 5G and 4G fairly noticeable
@Chris_ wrote:Hi there,
Thank you
Personally @Chris_ that extra 15GB of data at regular speeds is more important than the unlimited at 512kbps after 50GB. Just didn't see that big of a difference with speeds because your location is what matters. You may find 5G speeds with a 5G phone in your home area but your friends area or work area is slower. JMO.
EDIT: the 5G plan doesn't seem to come with unlimited at 512kbps in that offer so... the extra 15GB is more important than speeds IMO.
yesterday
HI @Chris_
all plans can use PM's 3G, 4G and 5G network
The difference is the speed you will get
Which ever network you use, a 3G speed plan give you up to 3Mbps, 4G plan gives you up to 100Mbps, and 5G up to 250Mbps
yesterday
@Chris_ Even though 4G is up to 100mbs and 5G is up to 250mbs its sounds like it’s twice as fast but in reality it might take 1-2 seconds longer to load webpage on 4G
