01-06-2025 11:34 AM
I'm in the US Before I left Canada I paid 15$ for US roaming. All I get is a busy signal for a few seconds and then nothing. Just now I paid another $30 and still no difference. What is the problem?
01-06-2025 01:39 PM
yes, the same one for sure won't work, but two set of addon overlapping won't work either. And in OP case, he does not need both of them anyway, so better to work with support to sort that out
01-06-2025 11:49 AM
@hTideGnow they can't work with each other
The roaming help page only clearly says you can't have two of the same, so it's a bit ambiguous when it comes to two different ones, it sounds like it should work but in this case there is an overlap of functions except for data. From the help file:
01-06-2025 11:40 AM
hi @JoeK
$15 is the voice and text roaming, $30 is the bundle, you cannot have 2 roaming together, it won't work
to use voice, try connect to T-Mobile and change the network mode to 2G and see if it works
but since you have 2 roaming addon, they can't work with each other, you might want support agent to remove one of them first and refund
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
01-06-2025 11:38 AM - edited 01-06-2025 11:39 AM
@JoeK For voice calls in the USA you need a phone that is "certified" for VoLTE by Public Mobile, see list here
https://www.publicmobile.ca/en/on/get-help/articles/volte
But does anything work? If the phone is not VoLTE it should still work for texting and data. Try setting to 4G/LTE if you are on 5G, and try each of T-Mobile, AT&T and Verizon. Enable data roaming if you haven't already.
