no network
Irena11
phone says no network and insert sim card
TheSterlinger
@Irena11  could be a temp issue. Few things to try:
Turn airplane mode on and off.
Reset phone network.
Try sim card in another phone. Does it work?
Phil_Adelphus
@Irena11  phone says no network and insert sim card
Can you give a bit more detail, is the phone actually telling you to insert the sim card, or you mean it says no network after you insert the sim card?   It is a new Public Mobile sim card?
eddieO
@Irena11 try turning off your device, then remove the SIM card and then place it back in the SIM tray to make sure it's properly seated, and back into the phone. Then restart the phone to see if it works. If it's still not working do you have another phone you can try the SIM card in to see if it's working?
